Puck or not to puck
1995 Z28 stock block, edelbrock, 1.6 rockers, cc503, PCMFORLESS tune, all boltons, 58MM TB, 32LBS injectors...
i honeslty have no idea what clutch to purchase...
could use a little advice
http://store.summitracing.com/partde...40+4294865886+
thanks for all the help guys
My $.02 is move towards a puc/puc type disc if you are going to spray. A number of clutch kits to chose from. Since the PP is the "Valeo" LT4 or clone the disc construction is the main difference between LT1 "pull" type clutches.
