T56 Install Trouble
T56 Install Trouble
Hello. I am installing a T56 for the first time in my 00 Z28. I have the "used" mcleod clutch & pressure plate in place with a new factory master and slave. I can't get the splined shaft in the tranny to match up with the motor. Any suggestion? thank you.
How did you install the clutch? Did you use an alignment tool? If not, that in itself is your problem.
Also, is this going into an Auto car, or was it a stick car to begin with????
yes. I used the alignment tool. I have two jacks holding up the trans and i have engaged the clutch disc. I just can't get the end of the shaft to slide into the pilot bearing.
So far my friend and I have 3 hours into getting the tranny to align. The splines are ingaged into the disc, just not going into the pilot. I am going to take the tranny down and mic the alignment tool dia, and then the shaft on the tranny just to double check. I assumed that they were the same.
ALSO:
If you engaged teh clutch BEFORE you got the input in far enough, the clutch disk could have dropped down some, and thrown your alignment off.
I also want to know if this is going into an auto car, or you just replaced teh clutch, or what? Why is the tranny out? I like details!
These are a bitch to line up sometimes, I've seen people have problems with the Dowels in the trans not lining up, or have one stay in the bellhousing and upon re-assembly it gets pushed through the bell housing. Both pins should be in the trans. check this thread, its got good pics of the pins and what happened. https://ls1tech.com/forums/manual-tr...h-failure.html
Even though he somehow got it to line up with one of the pins sliding through the bellhousing
Anybody know where to get one?
Typically the only "metal" ones are sawed off old input shafts.
For those of us who have done this fing with alignment is part of the deal. Do not force tranny in by pulling tranny in using bolts...you will kill the pilot bearing.
What I found helpfull is push straight in on clutch tool while tightening PP bolts enough to hold disc. Look and run fingers around edge of clutch. The "edge" should be even all the way around, not with on side of the disc sticking slightly out.
Turning rear shaft so tranny spline is at a different angle, man handeling it, etc. are all part of the process sometimes.
Do confirm that motor and tranny are "in-line" meaning the gap top and bottom of tranny is = spaced from bell housing. If not binding and tranny will not go in.
I'm just replacing the clutch. It was a manual car to begin with and it is the T56 tranny. I am going to take the trans back down and use a set of mics to measure both the input and the tool to see if they are close. There seems to be equal distance around the trans about a fingers width. We've tried putting the trans in gear and in neutral with no luck. I think it will just be a matter of time with plenty of man handling. I hope it works, I have to move the car very soon. My wife and I moved and its at the old house!
I might have missed it, but did you change out the pilot bearing (PB)? If so, maybe installed backwards? If not, maybe the old one is damaged??
Brand new pilot bearing and throwout bearing. pilot bearing is installed the correct way. Everything seems to be ligned up and we have two more hours today into trying to get it to line up with no luck. Still a fingers width away. OD of shaft on tranny and alignment tool are the same dia. Any ideas?
