Best 60's: M6-10bolt
jmill, that is just sick!
silverz28, my best 1/4 mile is a 12.06 @ 115.8 with a 1.81 60'. I ran a 7.79 1/8th mile that pass.
I miss shifted on the top end on the 1.76 60', but ran a 7.68 1/8th mile. It would have been an easy 11, but I screwed it up. However, I'm going back next weekend to get that 11 second slip.
Man, you sound just like me; I missed a shift on my best pass last Sunday which pisses me off cuz it would have been an 11 as well.
The "10-bolt" in the GTO is actually a Dana 8.5" similar to the old muscle car era 10-bolt. Its not the same as th 7.5" 10-bolt in the F-bodys. The GTo rear is much stronger, but I think that is where the confusion comes from.
Gotcha, thanks for clearing that up as I didn't know that info, thought that besides the IRS they were basically the same.
ive read about launching an m6 an will have more practice this season with my new ls7 clutch going in and tickmaster adj i already have. what does "slipping the clutch" mean.does that mean keeping your foot on the clutch and then letting off or "feathering it off" at 4k rpm launches? i also can't figure out side stepping? sorry for the newb questions but i will be doing a lot of practice at the strip this season.
#35
1.71 on stock gears, might have had non-adj. LCA's at the time but otherwise stock suspension (cant remember), Tex OZ-700, 275/40-17 ET Streets
#36
i dont have a spec 3 yet but i plan on getting one this spring, and i will have the 10bolt, now i drove my buddyes car with the spec 3 and its alot harder then a stock clutch im sure i will get used to it but is it hard to slip it?
#37
Spec 3's dont really slip well like a stock or full face clutch. The best you can really do is to let it out slowly so it kinda preloads the suspension. I put like 25 psi in my DR's so they spin just a little off the line.
#38
Only 1.89 w/ stock clutch, Nitto DR. Hoping for better 60' w/ new LS7 clutch and MT DR tires.
Aggie-chase what cam are you running, should be in the 11's soon w/ cam and bolt-ons only.
