Skip Shift Eliminator...
Old Mar 8, 2009 | 08:30 PM
00FlowCamaro's Avatar
Default Skip Shift Eliminator...
I bought one and put it on over the weekend and it seems to work flawlessly except for that it seems to be harder getting into reverse? When I move it over to go into reverse it takes some effort to get it over and up. Any thoughts?
Old Mar 9, 2009 | 06:50 AM
calhoon's Avatar
You mis-plugged the eliminator( installed it in the reverse sol)
Old Mar 9, 2009 | 08:34 AM
So then where is the one that I actually plug it into? So even though I installed it in the wrong one how does it still "work"?
Old Mar 9, 2009 | 12:45 PM
calhoon's Avatar
A couple of things can cause this. On a re-install, getting the skip & rev plugs mixed up. It may also be that the fuse is blown for the circuit. Even if they are plugged in correctly, there would be no function.
The reverse solenoid is the one near the shifter on the tail housong. The skip is on the main case.
Old Mar 9, 2009 | 01:05 PM
teke184's Avatar
drivers side of the trans
Old Mar 9, 2009 | 02:02 PM
Hmm gonna have to grab the jack and crawl under there again. I unplugged the sensor, so I thought, from where it says in the picture. Then I took the sensor and plugged it in where i removed that plug. Are there two plugs you have to remove?
Old Mar 9, 2009 | 07:43 PM
teke184's Avatar
nope just one....
Old Mar 9, 2009 | 09:46 PM
the_merv's Avatar
Yea sounds like it's plugged in the wrong one..
