T56 in a 99 v6 camaro
As said, can be done, but teh ? should be: Why?
If your tranny blew up, and you have a free T56, then OK, maybe, outside of that, not really sure why you would want to go through teh trouble.
if you were building a race car with a v6....turbo, s/c, or nitrous....and wanted the power capabilities of the t56, along with the 2x OD so you can run good gears.
its totally feasible.
there are a few companies that specialize in engine adapters.
off the top of my head, i think one is "trans-dapt" or something like that.
Yes this can be done and bolt-in. You would need to get an aftermarket model T56( 1386-000-011) and an older bell with the bowtie bolt pattern ( instead of the Ford pattern the orig T5 used). Modify the propshaft, yoke & crossmember location.
