Clutch question?
Old May 4, 2009 | 10:59 AM
cammin z's Avatar
Question Clutch question?
i just got an ls7 clutch and it came with an ls7 flywheel, can i use that flywheel or do i need and ls2 flywheel??? i have a 01 t/a 6 speed car... please let me know!
thomas
Old May 4, 2009 | 12:04 PM
cammin z's Avatar
nothing??
Old May 4, 2009 | 12:15 PM
Aster's Avatar
I believe to use that clutch on our F-Bodies you have to get the Corvette style LS2 flywheel. That is what I had to do when I had my LS7 clutch, went with a Fidanza aluminum one to keep the weight down on the clutch assembly.
Old May 4, 2009 | 12:18 PM
BADZ's Avatar
Moderator
You will need an LS2 Flywheel, with the LS7 clutch disc, and pressure plate.
Old May 4, 2009 | 12:58 PM
chrysler kid's Avatar
i used the ls7 ?????
http://www.sdparts.com/product/SDLS7...cFlywheel.aspx
Old May 5, 2009 | 07:22 AM
cammin z's Avatar
??? hahah wow sooo i guess i can use the ls7?
Old May 5, 2009 | 07:56 AM
B-RAD2's Avatar
I used the LS2 flywheel!!
Old May 5, 2009 | 11:30 AM
BADZ's Avatar
Moderator
Let's please hear some specifics on your clutch install with the ls7 flywheel if you don't mind..Do you have an ls2?
I'm pretty sure the question above is will an Ls1/Ls6 engine bolt up to an ls7 flywheel?
Originally Posted by chrysler kid
Old May 5, 2009 | 12:02 PM
cammin z's Avatar
^^^^yes i have an ls6 with a t56 trans.
Old May 5, 2009 | 12:40 PM
BADZ's Avatar
Moderator
Let me sum it up:
The ls7 clutch pressure plate is different than the ls1/ls6 pressure plate, so if you try to bolt it to your stock flywheel it will not work (hole alignment), but if you get the ls2 flywheel (which comes in the ls7 kit from scoggin dickey) that will bolt up in place of your old flywheel allowing you to attach the ls7 pressure plate. (and disc)
This would be a better fit catagory here....
Old May 5, 2009 | 01:13 PM
cammin z's Avatar
^^^ thankyou now i got it, well looks like ill be hitting up the parts department at work today to get my flywheel! Haha
Old May 5, 2009 | 01:34 PM
Originally Posted by BADZ
Let me sum it up:
thank you sir. i just know i bought their ls7 clutch kit for the ls1 when they had a group buy and everything just bolted up.
Old May 5, 2009 | 02:37 PM
topher455's Avatar
How do you like the fidanza / ls7 setup? I was considering it. Do you drive on the street much?
