New master, line, and slave still wont shift at WOT
I am having problems with my clutch and shifting. Its getting very very old and makes me want to go back to an automatic. The clutch is a ls6 package, flywheel, PP, and disk. I get one good shift out of it and then its retarted for a while and wont kick the pedal all the way back and doesnt want to shift. I was just wandering if anyone else has had these problems with the ls6 setup. It feels like it slips for a split second till the PP clamps back down on the disk again. Like 1/10th of a second of slip and its clamped back down. I have another ls6 PP im gonna put on probably tomorrow or maybe tonight. But does anyone else think this could be the PP causing this. Also i shift at around 6500-6600 rpms.
Jon
Jon
I bled the **** out of them with a mity vac. And its a after market 3an line so no drill mod. I have been having this problem for a long time. And the clutch has been bled countless times. I had this issue before the new motor it just wasnt as bad I am pretty sure that the more rpms I am turning now are making this worse. Also the is pretty much zero chance that im getting the fluid too hot because i have the clutch line running through the firewall into the cab and back out the trans tunnel.
Jon
Jon
I'd put money on the pressure plate. I just had a similar issue with an LS6 setup on mine. It would shift just fine at normal speeds, but when I accelerated hard, the clutch pedal would get stiff and not disengage the clutch above 4500rpm's. Then I'd have to pump the pedal several times to get it to disengage. I just replaced the whole flywheel/clutch with a Monster Level III. Now I'm a happy camper. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Mike
Mike
Can you see the PP being defective when the tranny comes out? i have a similar issue in my cammed CTS-V im running a 7 month old ls7 setup and every since its been cammed i can only slam 1st to 2nd above 5k any other gear when i go to shift i feel like im pulling it out of gear sometimes and it will not going in any other gear untill i lift the pedal and pump it
![Ripped](https://ls1tech.com/forums/images/smilies3/ripped.gif)
LS1TECH Sponsor
Jon
Jon
less than 15k miles ago the transmission was rebuilt by Jason at TDP so I doubt its my syncros and it only happens at WOT at high rpms. I have narrowed it down to a clutch though.
I'm thinking that the culprit is your clutch. The LS6 was not designed to hold the power you are making, or the weight of your truck. I would start looking around for an aftermarket set up.
My LS6 clutch did not last long at all in my GTO after I did a cam. It would allow me to do a 1-2 and sometimes a 2-3 shift then the clutch pedal would become a brick, and I would have to wait a few seconds for it to loosen up and to be able to shift again.
I replaced it with an LS7 and after a few months that started to slip and I noticed my car getting slower. Now I have a Monster Clutch, and the shifts feel great! No slipping, and the car honestly feels faster, probably because I'm able to get the full power to the wheels now.
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
Funny how people down play the stock clutch.
Listen I have a LS6 clutch in my camaro and its a DD also been to the track nurmous times at least 200+ track it put down 335HP/350TQ. (that's at least 400 at the crank) passes and the first thing to go out was the rear end. So I highly don't think its the clutch unless you installed it wrong user error..!!
