Why so many flywheels?
Some shops claim that you need a billet steel flywheel for some disks, but I ran the roughest disk material that RAM had to offer on my stock flywheel with no problems.
Josh
If the flywheel were, say, cut in a lathe, its highly likely that a parallel surface will not be attained, and cutting the crank side of the flywheel flange could amplify the problem. My main point is, find a reputable place to grind the flywheel using the proper surface grinding machine and cutting the flange will not be necessary...
The other issue on changing to aftermarket flywheels is safety. I personally would not care if one of our customers used the stock flywheel, but would NEVER recommend it. Using a pressure plate other than the factory metric pattern/drive pins, the clutch cannot properly locate unless it is redrilled for the aftermarket unit. Steel is best for drag/street apps, aluminum for road race, autocross, or apps where you want to use the engine as a brake. MOST aftermarket flywheels are SFI approved, meaning explosion resistant, which is a good cushion of safety on our cars that do not have a scattershield available...
