Won't line up with poly mounts...
I got it all lined up even made a trans plate to hold up the trans on the floor jack, works great...but I can't get it to line up. The engine is sitting too high and the bellhouse hits the trans tunnel.
The stock mounts would've given me the angle I need but, it seems like my new poly mounts hold the engine up. It seems like I need to drop the K just to get it to line up.
Anyone else have this happen???
Been thinking about it all night...I'm going to unbolt 2 of the rear kmember bolts. I'll place another jack under the oil pan just for additional support. This may give me the 2-3 inches I need. Wow this sucks!
I've got 20miles on my setup so poly mounts are new.
I'm going to do a writeup on a trans jack. It works perfect!! And it can be done by one man.
Thanks just confirmed what I thought...
I have poly engine mounts and mine trans lined up two times without a problem. I use a jack for the trans and once I get it so that it looks like it's lined up good with the bellhousing (ie; parallel mating surfaces), I grab the end of the header collector and rock the engine slightly while pushing the trans toward the bellhousing. Like I said before, worked like a charm both times I installed the trans. Maybe this will work for you also.?
Mike
Mike
Well I've also got a BMR K and the brand new poly mounts. No rocking of engine, they were stiff. A quick background...built a new 408 with an A4, trans lost 3rd in 20 breakin miles, dropped the a4 and swapping the T56. So everything is tight...there was very little flex in the mount. With the iron Lq9 you'd think there'd be more flex.
T56 tranny crossmember, tranny mount (can use A4 tranny mount - recommend LS1/1LE tranny mount)
Found here...and referenced in the A4->M6 Thread However, if you already have it, sorry. Disreguard
http://www.afrashteh.com/tranny_pics/T56.htm
