Spec Stage III - Daily Driver - Master question
Old 11-13-2003 | 12:01 PM
Crowley's Avatar
Default Spec Stage III - Daily Driver - Master question
With a Spec III and stock 3.42 gears on a daily driver, do you think an adjustable master is needed? Should I spend the extra $$?
thanks,
Crowley
Old 11-13-2003 | 12:52 PM
SlickVert's Avatar
I was wondering the same questions. Icalled Spec today and talked with Dave, he said the stock OEM 2001 or new is recommended.
Old 11-13-2003 | 01:20 PM
97M6Formula's Avatar
Ive been using stock master I my 97 for about 2000 miles now and I love it. Engagement point is perfect way up top for quicker shifts
Old 11-14-2003 | 01:13 PM
Steve Burger's Avatar
LS1TECH Sponsor
I updated to the new GM stuff and have about 30 passes and no issues. daily driving is fine. I would not spenf the $$ on an adjustable master. JMO
Old 11-14-2003 | 02:15 PM
bad2000ss's Avatar
Spec also recomends using the Shim they include with the clutch package to raise your engagement point a bit. I don't know if it was the new master and slave or the shim, but after installing the spec clutch, the trans shifts SOOOO much better than with the stock clutch. It is easier to put in and out of gear. Almost as if the stock clutch was not disengaging completely. IMO i do not think an adjustable master will be needed, unless you find that your engagement point is at one extreem high or low after your clutch install.
Old 11-14-2003 | 04:53 PM
T-maxx's Avatar
thanks,
Crowley
No it is not needed.
Old 11-17-2003 | 04:38 PM
JMBLOWNWS6's Avatar
Shim it drill it run it everyday! I do and no problems. 2001 car
Old 11-17-2003 | 05:43 PM
PlainwhiteZ28's Avatar
not needed,
but after 3500 miles, It was awesome being able to adjust for the break in period.....
just my .02
Old 11-17-2003 | 07:51 PM
VSGLS1's Avatar
Probably not needed, but I also like have the option to adjust if need be.
