Help with air in the lines!!
I've got a tick adjustable master, monster stage III clutch, new gm slave. I'm trying to bleed this thing but I can't get rid of the air! Right now, I'm using my mity-vac, and there is some major air in this thing. I've got the pedal adjusted pretty low to the floor, and when the clutch is at its normal resting position you can pull it back up just a hair. When you play with this slack in the pedal while having the mity vac hooked up, you can see like inch-long beeds of air coming out of the mity vac. If you cram your head under the dash and play with the pedal you can hear a faint squishy noise.
By slack in the pedal, I mean its like the pedal doesnt return all the way to the top of its range (and no I don't mean all the way back to the stock pedal height). If I grab the pedal with the top of my foot I can move it back and forth with almost no resistance, and while doing that I see some major air bubbling up from the reservior.
I've been doing this for about 20 minutes and it doesnt seem like its done giving up air. Am I sucking air in from somewhere? I really hope it isnt the slave
. I did notice that when I put the hydraulic line into the slave that the little stem coming out where the line goes in seemed a little wobbly. Help!
it was pretty amazing what a traditional bleed will do sometimes. I'm not having issues getting it in gear, just engagement. It just doesnt seem to engage very smoothly.
I also didn't remove the spring at the top of the clutch pedal. Could this be part of the movement in the clutch pedal?
