Tick Remote one man bleeder
Any body have One and if so What do you think of it. Pros,cons and how does it work thinking about picking one up soon Thanks.
Yes I have one. I stuffed it on when I dropped my 454 to put in morel lifters.
Helps 100% as I had the end of the hose under the rocker panel while I was in the car pumping the clutch pedal. All the air escaped then I tucked the steel line up under the body ! Really nice as you don't have to try n get a socket on that damn bleeder @ the slave cyl......
Okay, I have a quick question about these.
I just bought one and put it on when I did my clutch swap yesterday.
Problem I'm running into is I'm not exactly sure If I'm bleeding my system right. I did the drill mod and put in a new slave, so I know that I have alot of air in the system. But I dont seem to be making any progress on it. I just spent 3 hours and 4 quarts of brake fluid today trying to bleed it with no luck.
I tried the traditional method of pushing the pedal, opening the bleeder breifly, then closing it and releasing the pedal. Then I tried putting the end of the line in some brake fluid, leaving it open, and pumping the pedal. But I still dont feel like I'm making any progress.
I've been doing both of these with the car jacked up and the line running under the car. Am I supposed to elevate it into the engine compartment? What am I doing wrong?
To the OP: A remote bleeder is a no-brainer when you replace your clutch.
First, let me say, you have one VERY nice Avatar pic
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
2)When you explained the above, are you topping off the MC every 3-4 times of cracking it open? If you run that MC low at ANY time, you just let air back in, and back to ground zero.....So??
on the tick bleeder, crack the bleeder open about 1/4 turn and start pumping the pedal to flush out old fluid. make sure you dont run the reservoir dry. after your done doing a complete flush, close the bleeder and pump the pedal until there's no more air.
Took your advice and may I say it worked like a charm. Only took me about an hour to get all the air out after I borrowed my brother's mityvac. Got my car running finally and I'm already 50 miles into breaking in my new Monster clutch and Tick t56.
Awesome. It's a must when bleeding our hydraulics.
