T56 question
Old Oct 19, 2009 | 06:48 PM
z28camaro1996's Avatar
Default T56 question
when im going down the road 75 to 80 i get a vibration from the tranny and when i put it in neutral it keeps doing it if not worse i wounder what it could be?
Old Oct 19, 2009 | 07:09 PM
Gen414's Avatar
UJoint or Rear end...you SURE it is tranny?
Old Oct 19, 2009 | 07:53 PM
well i just rebuilt the rearend and ive had the car for about 5 years and never replace the u joint but ill replace it and see what happends
Old Oct 23, 2009 | 12:49 AM
i replaced both u joints and it still vibrates. so im guessing its the drive shaft or the tranny.
Old Oct 23, 2009 | 01:54 AM
squee's Avatar
Sounds like the driveshaft is out of balance. Slug tire weight would be my next guess but sounds like your pretty sure its coming from the tranny or driveshaft, so I dunno...Maybe a rear wheel weight?
Old Oct 23, 2009 | 09:16 PM
i feel it mainly from the gear shifter and right under me
Old Oct 24, 2009 | 12:00 AM
Ketis's Avatar
did this happen before you rebuilt the rear end?
Old Oct 24, 2009 | 02:51 AM
yea i did the rearend rebuild myself and all the bearings checked good.
Old Oct 24, 2009 | 03:12 AM
the_merv's Avatar
I'm leaning toward that wonderful LT1 Stock Steel Drive Shaft..get a LS1 Aluminum one.
Old Oct 24, 2009 | 02:10 PM
my drive shaft is aluminum. it was made in 2002 by spicer.thats what the sticker says any ways
Old Oct 24, 2009 | 02:36 PM
the_merv's Avatar
Wow..that's suprising..check the Pinion Nut.
Could be tires too.
Old Oct 24, 2009 | 03:58 PM
jutt26's Avatar
rotate the rear tires to the front to verify if its the tires (vibration should come through the steering wheel at that point).
Old Oct 24, 2009 | 05:55 PM
Could be tires too.
i changed the ujoints and noticed that it was aluminum. it shock me to cause ive had the car for nearly 5 years now. ill rotated the tires tomorrow cause i have to work tonight ill keep yall posted on what happends
Old Oct 24, 2009 | 05:57 PM
pinion nut was fine we put locktite on it at the rebuild just last week
Old Mar 18, 2010 | 11:12 AM
sorry i forgot about this post cause i drove my truck for a while. i rotated and balanced the tires and still vibrating from the middle of the car. i had it on the lift last week to change the seals on the timing chain cover and noticed that the seal in the tail shaft was leaking a lil bit. and today i pushed the car a lil bit i noticed when i hit 75 through 85 or slower its the worst.i geared down to 5th it kinda smoothed out when jumping down on it. and it stayed the same from 85 to 100. then when i put it back in 6th it seem to get a lil more vibration from it.
Old Mar 18, 2010 | 03:07 PM
when the vibration smoothed out it didnt quit all the way cause i could still feel it
Old Mar 18, 2010 | 03:39 PM
SSmoked1's Avatar
Mine does the same thing but it's an auto. Had new spicer u joints installed and the drive shaft checked for balance. Same problem. Then replaced the transmission mount with a poly unit. Same issue. Replaced the rear end with an LS1 one I had. Same issue. I'm really thinking it is the torque arm mount. Vibrates your *** and shakes your passenger seat when nobody is sitting there? The auto is coming out so I'm not able to replace the torque arm bushing but that is a cheap fix. Let me know if you get and it works or not.
Old Mar 18, 2010 | 04:44 PM
OK when you switch over and its gone let me know as well.
Old Mar 20, 2010 | 11:29 PM
the new torque arm bushing took care of it. i took the old one of and it was still the oem two peice one. it was really soft and cracked in the middle.
