T-56 Dexron III
They look like a flat charcoal colour. (the carbon ones)..
The "paper" ones looked very similar to me. (unless my trans had been rebuilt before?) But I doubt that, I bought the car at 56k miles, at a dealer and no history of rebuilt trans.. Besides, everything else in the T-56 looked stock..
Kleeborp the Moderator
I've run a few different oils in my T-56 (both my old one and new one), and so far, I've liked the Torco ATF the best out of the ones I've tried. I have regular el-cheapo O'Reilly's Dex III ATF in there now while I was chasing down a leak, and I personally thought it shifted better with the Torco. Maybe that was just my mind telling me that the more expensive Torco just HAD to be better, but I'll be switching back to the Torco after my next clutch swap in the spring.
This is correct according to attached article:
http://www.sandyblogs.com/techlink/2...dexron-vi.html
http://www.bobistheoilguy.com/forums...Number=1415606
As you can see, Dex VI should NOT be used. I use Mobil 1 ATF in my Six Speeds Inc T56 because that's what they recommended.
Thanks for the pics guys..
Yes there is a difference, but still they look pretty similar (In comparison to other transmissions that have brass blocker rings!)
But thanks for the clarification..
#33
FYI
The T56 holds 4qts of fluid. ATF Dextron/Mercon III, IV is a revision and is compatible.
"Until the mid-2006 model year, all six-speeds will be produced filled with DEXRON III fluid, although the transmission has been validated for used with new DEXRONŽ VI. In mid-2006, the six-speeds will come filled with DEXRONŽ VI, which was developed to behave more consistently during temperature and other environmental variations, as well as to provide even lubrication of the moving surfaces of the transmission."
#34
FYI
#35
nope got that from a post on here from a while back.
https://ls1tech.com/forums/manual-tr...-write-up.html
good info here
good info here
#36
good info here
good info here
so many opinions
what is FACT?!
Still, I see sticking w/ Dexron III cant hurt
