Aftermarket clutch line????
does anyone make a clutch line for the m6 ls1 that is better than the factory part? I have been through 2 of them and I am geting tired of changing them. Any thoughts???
if anyone needs a line made, call McLeod's Tech Line (714-630-3668). They have the "GM" quick dissconnect and can make lines in whatever length you want. If you are putting it to a "GM like" master (with the roll pin), they have that end also. If you are just hooking to a "standard" master (no roll pin), they put a 4AN end on the line and then you can use a 3/8-24 banjo.
old thread but TTT for this info...
i was wondering what banjo size i needed for my master cyl.. and im not too thrilled with the idea of pulling it out just to measure.. lol.
