New Tick Master Cylinder Leaks!
I have a tick master cylinder on my car and I love it! I am doing a build for my friend and just tried to bleed his clutch. Turns out master cylinder is leaking fluid all over the floor and it wasn't from the reservoir hose. It is brand new so hopefully you guys at Tick Performance can tell me how to fix it. I am going to pull it out and check it out tomorrow. Looks like it is leaking where the braided line connects to master. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
His build thread:
https://ls1tech.com/forums/forced-in...c-build-5.html
His build thread:
No one has anything to say? Especially from Tick Performance...?
I mean my buddy bought a tick master cylinder and you sent one for a vette even though it said 2000 camaro on the receipt. He had to pay the extra shipping costs to return the first one and then you send one that leaks and can't respond to a thread....WTF
Well their shop is closed on Sundays I am sure. This is not a way to contact a business, thur a forum. I would call them and leave them a voice mail with a return and number with your issuse, and I am sure that they will return your call Monday morning. I would like to see pictures if you can get a camera down you where you say it is leaking.
-Sean-
-Sean-
-Sean-
-Sean-
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
-Sean-
-Sean-
LS1TECH Sponsor
His build thread:
His build thread:
I usually log on here atleast once a day to check pm's, but I rarely search the board for threads that mention us.....
LS1TECH Sponsor
I tighten them all before they leave so they are positioned correctly (on the f-bodies). Theres a chance it could have been broken lose when installed....
Theres a blue earls fitting that screws to the end of the master than can be tightened with an 11/16" wrench. Then a braided -4 line screws to that and can be tighened with a 9/16" wrench.
LS1TECH Sponsor
Don't get me wrong.....I love my tick master cylinder in my car.....but first I am sent a corvette master cylinder and now a leaking f-body one.....that's just ridiculous .....then when I got them on the phone all they could say was get a picture.....uhh the brake fluid is everywhere and it's kind of in a tight spot for a camera......I will most likely just take it off the car and let owner deal with them ![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
As for the leak, I have told you what to do to fix it. We get a lot of calls, and we've only got one line and one guy answering it. I'm not sure when you got us on the phone, but the way this thread reads it seems that I've given you the suggest method to fix your issue before you even tried to call.
I appologize for any trouble you've had getting us on the phone, but until you try to tighten the line theres not much else anyone can do...
When you order a cylinder for a vette, thats what we send you. It amazes me how many people will order the vette one because its cheaper, then call back to ask why it doesn't fit their camaro...
Got master cylinder out...looks like the white plastic piece that the reservoir connects to has a hairline crack. I don't know if got damaged while installing it or if was damaged before hand. Either way Tick is sending a replacement cap ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Edit: Got a magnifying lens on it and it has a pin size hole in it......maybe was a manufacturing defect
