difference in standard and "+" spec clutches
We actually offer Stage 2+ (which is a hybrid that uses a pucked face on one side of the disc and segmented kevlar on the other) and the Stage 3+ which uses a full-faced carbon-semi-metallic face on both sides. In general the "+" kits offer better capacity and/or drivability than the other units. For our current LS based offerings the difference wil be relative to the disc material rather than the plate design. I hope this info helps. Let me know if you have any further questions. Thanks,
thanks for the info!
The setup is a 02 Z06 supercharged 600-650 rwhp.The car wont see any track dumps just roll stuff.
I want a smooth clutch but that will hold and have no pressure plate(pedal) problems.
I had a spec stg 3 years ago in a f bod and loved it but had a little chatter
would u recommend stage 2+ or 3+ ?
