Reverse lockout on a4 to m6 swap
Hey i know there is a specific thread for a4 to m6 swaps but i couldnt find a clear cut answer on what guys are doing about retaining reverse lockout on the t56. I know it will still go into reverse if you force it but it is a pain in the ***. other guys are saying that they take the lockout off completely. It feels to me like it would be way to easy to slide into reverse on accident. I have also found that other people will install a switch that energizes the solonoid that alows it to go into reverse easily. I dont really want an extra switch on the inside but that is the option i am leaning towards right now.
Thinking of wiring the reverse lockout up with my brake pedal switch. When the brake is depressed the solonoid will open up and allow reverse to be easily accessed. Any better ideas?
I just did this on my a4-m6 swap. I found some good info on a few posts on here... If you are 99+ then you can re-build your a4 harness to work with reverse lockout, assuming you get the PCM an m6 tune...
Here is what I did -
Part 1.
On the red PCM plug, Unpin #42 (tan/black wire on my 00'), insert into unused pin #44
Pin #42 was used for the A4 TCC
Pin #44 is where the rev lockout ground is.
Part 2.
Trace the wire from pin #44 to the old a4 connector pug, remove the wire from the a4 connector plug and connect it to the rev. lockout pigtail. (this is the ground signal)
Then, take one of the two pink wires from the a4 connector plug and connect it to the rev. lockout pigtail. Both pink wires are hot with ignition on.
As long as your car is 99+, and have the PCM flashed to an M6 (I did so with HP Tuners), you will no longer have to fight reverse under 5mph - or whatever speed you decide to set it to in the pcm.
Ka-chow
Part 1.
Part 2.
Ka-chow
I may do this on my caddy as it seems the computer forgets it controls this function of my car from time to time. Sometimes it won't let me in reverse when I want to and sometimes it's open like a 5 dollar ho when I'm running 75 down the pike. Ever since I installed the tuned PCM. I guess you say they can change the parameters for this when they are in the computer? Maybe the jacked mine up somehow.
So i was planning on just reflashing the pcm with a tech 2 using a m6 vin. However My car has an ls6 intake (no EGR), and offroad Y. Should i just buy a tuner that can get rid of these codes? What should i get? How much am i looking at spending? I know its the wrong thread for this but you guys have been helpful so far so why not try!
Whats even cooler (if you're cheap like me), is that you can structure future mod plans based on existing dyno tested tunes in the repositories & in theory skip 250-500 buck one time fees at tuning shops or mail order tunes - at least that was how I justified the expense to the fionce
I am about to finish up my swap this weekend, I see some posts on this subject refer to adding a diode, stating it's in the factory schematics. It seems most are hooking this up with no mention of the diode, nor do I see it in my GM factory service manuals, could the diode be a 98 only deal?
