Do they make plugs to go into the ....
Old 01-12-2004 | 01:33 PM
98Z-6Speed's Avatar
Default Do they make plugs to go into the ....
skip shift receptical on the tranny? I successfully disabled skip shift using the 1/2 watt resistor from radio shack, but I am unsatisfied with just covering the empty receptical on the tranny with electrical tape, I don't think that will hold well. Do they make plugs that fit well into that type of thing, or do I have to buy the overpriced skip shift kits?
I am satisfied with the job I did covering the now unplugged wire loom.
Old 01-18-2004 | 03:20 PM
Orange99Z's Avatar
I just did mine with the Radio Shack resistor too($.99 for a 5 pack.) I pulled the rubber seal off the connector on the harness side and filled it with some silicone. When it was dry I put it in the empty receptical on the tranny then taped the crap out of it. Does that make sense? I didn't like the idea of just tape over the hole.
Old 01-20-2004 | 12:57 PM
98Z-6Speed's Avatar
Ok, I gotcha, that sounds like a great idea. Thanks a lot. I am going to try that this week. I HATE the idea of just tape over the hole.
Old 01-20-2004 | 01:01 PM
Bugsquawsher's Avatar
Why???
You think you Might want to hook the skip shift up again?
Besides there is no power to it , so corrosion is not a problem.
Old 01-20-2004 | 03:29 PM
98Z-6Speed's Avatar
Originally Posted by Bugsquawsher
Why???
I read somewhere that if dirt/water gets into the hole it will set a code. If that is not true, then I won't worry about it. Anyone know for sure?
Old 01-20-2004 | 03:50 PM
66ImpalaLT1's Avatar
It cant set a code because its not hooked up to the pcm.
Old 01-20-2004 | 05:01 PM
Cal's Avatar
Cal
Another option is to just leave the cable plugged in, then use LS1edit to disable the skip shift function.
Old 01-21-2004 | 08:55 AM
jerflash's Avatar
if you buy the skipshift they give you a plus to put in there
Old 01-21-2004 | 09:26 AM
98Z-6Speed's Avatar
Thanks everyone for clearing this up for me.
