Shifter question
1) Hurst Billet Plus
2) B&M Ripper
3) Pro 5.0
Which has:
A) Shortest shifting throws?
B) Most firm and crisp shift?
C) Best quality?
D) Best fitment?
Any additional comments are welcome, but please try and focus on the main questions at hand, thanks.
Not that many people have tried them all. So your comparisons will be tough.
I have never even heard of the hurst billet plus.
I can say this,
THe stock set up was ok if you weren't racing , for me anyhow.
How bout a break down.
The stock shifter is a two piece unit.
You can put a different handle and do away with the rubber damper and get a more firm and shorter throw.
The Pro 5.0 is also a two piece unit. you can put a few different handles on this one too, I see Lou's short stick for one.
The B&M ripper is a one piece unit. It seems a bit shorter than stock. But solid as hell.
The feel is solid , the shifts are solid and crisp. and you dont' have any bolts that can back out on you. It bolted right up and with the washers they give you , you can shift the whole thing forward or back.
I like the Ripper , but I will tell you one Little thing I don't like. When going into reverse the shifter hits the console a little.
Slightly shorter throw (Lous short stick available), Adjustable centering spring tension. Great quality though slightly Notchy at times. More vibration than the stock or factory Hurst. But the trade off is a more positive feel.
Can't go wrong with a company thats been building Shifters for almost 50 yrs. JMO
Hurst with lou's makes very little noise unlike other shifters and feels great
