2000 ss clutch sticking on floor
Got a question I have a 2000 ss Camaro and at high rpm I can't shift. I have read alot of posts on here and it seems to be the master cylinder!!! I can also be sitting still rev the car to 6000 and the clutch will get stiff and it catches very close to the floor and stays there I can pull the pedal back with my foot and pump it a couple times and its back to normal. I can drive at normal rpm all day and not have a problem. Need help bad any would help Thanks!!
First check the clutch fluid level and then the color if it is brown then the clutch fluid needs to be changed out. Just trying to tell you check the simple signs before tearing things apart. Hope someone else chimes in. Good luck and I do hope it is a simple fix.
even 01s and 02s suffer from this. the hydraulics suck, the fluid gets too hot and looses pressure. the majority of the time replacing the master with an aftermarket unit such as the Mcleod or Tick solves the issue, i went with tick, this monster piece is sure to last.
Mine would only do it when I slipped my clutch from a launch. When I changed my stock clutch out for a Spec 3, I also put a new GM master cylinder in it and a newer GM slave. My buddy Jamie made the master adjustable and we did the drill-mod and it works flawlessly. Good luck man. Oh, and for WIW, his 02 SS was having the clutch-drop issue between ever gear until he put his clutch in. He also put a Perfection-brand slave in it from Advance Auto and made his master adjustable and VOILA; it was fixed.
mine does this too..and its mostly cause the clutch return spring flew out of it and i have been lazy and havnt bought a new one so if i mash it hard and often it will stick some times.. make sure that your springs there..lol
On a side-note, the drill-mod is a must. I bought my master cylinder from our local dealership just a couple of months ago. The stock master's had the restriction that you're supposed to drill internally; these new masters from GM have the restriction in the brass fitting right on the end. This made drilling it even easier and you can see the entire hole to make sure it's round and not oblong.
