how to trim poly trans mount
Old Jul 20, 2010 | 09:09 PM
silversrtman's Avatar
Default how to trim poly trans mount
Ive read about people shaving the pre load bumps on the bottom of the energy suspension poly trans mount. I also am having vibration issues from the height difference of the current mount thats in there (prothane) and the stocker (1.8" for the prothane and 1.55" for the stocker) I tried to use a razor blade, a file, nothing is working, the poly is too tough. Anyone have any suggestions? I was thinking about using the bench grinder but that will most likely clog up the wheel....im out of ideas.
Old Jul 20, 2010 | 09:13 PM
Arc00TA's Avatar
Find a sidewalk. Rub it on the rough concrete. No bullshit it takes like 5 seconds to shave it down flat. I've done 3 or 4 ES mounts like that.
Old Jul 21, 2010 | 06:28 AM
innovative lol i like it....i will try that
Old Jul 21, 2010 | 07:15 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Or a bench grinder, I also have used the sidewalk method!
Old Jul 21, 2010 | 10:23 AM
therealcreeper's Avatar
I used a hacksaw
Old Jul 21, 2010 | 02:33 PM
BALLSS's Avatar
not sure what year car we are talking about..
if you have the factory shim (for LT1 years) you could remove one to make up for the taller height.
Attached Thumbnails how to trim poly trans mount-clutch-install-12-tranny-spacer.jpg
Old Jul 21, 2010 | 03:27 PM
Arc00TA's Avatar
It really works, I figured it out after the same frustration. I was sitting in my garage on the concrete and just went to town, it rubbed off like an eraser.
Old Jul 21, 2010 | 03:32 PM
Ive got a 2000 SS...so i dont believe there are any shims
lol sounds like what i was doing....i was trying all these different things and then i was just sitting there staring at the floor frustrated....except i didnt rub it on any concrete
