quicktime bellhousing and monster stage 3 - does it fit?
The quicktime bellhousing says you can only use upto an 11" clutch. Not sure what size the monster is 11" or 12". Just curious if anybody uses the two together and if they fit ok. Thanks
Ryan
Ryan
So now I'm not sure if it fits again. I think quicktime's specs must be wrong or I am reading them wrong. Their site says 11" for clutch size. Not sure if that is max or not. But all the flywheels are the same size so it must fit a 12". Right?
hey all i know is i ordered the regular monster stage 3,not the 11" race unit,and it fit just fine in the quicktime bellhousing.I didnt actually measure the clutch because i had no reason too,but i would assume it was 12",as thats all i paid for,and it was the same size as the flywheel.
Thanks. Yeah I'm assuming that the clutch size shouldn't matter because it isn't bigger than the flywheel. Maybe on a twin or triple clutch it might matter if the bellhousing tapers in too much.
I got the bellhousing today. Just gotta decide what clutch I want now. Kinda waiting to see how the Monster twins look and work. Bellhousing is a very nice looking piece. Hope it fits as good as it looks. Thanks
Ryan
Ryan
where did you find a price and specs on the monster twin disc? i looked on there website, but i couldn't find it.
i am runnin the monster clutch stage 3 puck style with chromeoly flywheel as we speak with the quicktime bellhousing. My quicktime bellhousing needed a little trimming where the bleeder valve sticks out so you might want to partially bolt up the bellhousing and slave to make sure it has enough clearance. I had to take a screw drive and pry up on the bleeder valve to get a socket on the endo of it when it was not trimmed.
