Flywheel need replaced when doing clutch??
I got on alldata to get some torque specs and info and it says when replacing the clutch the flywheel needs to be replaced. Is this true?? Or can the flywheel be resurfaced?? I have a really bad shutter when taking off from first gear so I was thinking the flywheel is warped.
The stock flywheel can be resurfaced and I suggest that you remove no more than .015". If it requires that you remove more to achieve flatness then you should buy a new flywheel. We offer both Billet Steel and Billet Aluminum flywheels for this application and I would be more than happy to assist you if you need a new one or have other questions about resurfacing the existing wheel. Just let me know. Thanks,
