Someone tell me what happened here. PICS
This was the result of a 6K or more clutch dump on 28" slicks. The car is making right at 500whp, has a BMR full length TA with the relocation crossmember. So the TA is no mounted to the trans. I have a spec stage 5(this is my guess). A few weekends ago I broke a lingenfelter 3.5 aluminum DS doing the exact same thing(6k dump). So I had a local drive shaft shop build me a 3.5" steel driveshaft. I couldn't re-use the aftermarket slip yoke from the lingenfelter because it twisted the splines. So I used a stock one I had lying around.
Well it broke the ears off the new driveshaft, ears off the slip yoke, twisted the splines again, busted u joint in a million pieces, broke the tailshaft completely off, and busted the front of the case(close to the output shaft). It also broke my 9" center section. Not sure exactly why's broke in there, but only one axle was spinning. I have a spool lol. So here are the pics...tell me this is just from over powering stuff lol.
![](http://i21.photobucket.com/albums/b265/Brittany-O/c87dfe48.jpg)
![](http://i21.photobucket.com/albums/b265/Brittany-O/02e24cf8.jpg)
![](http://i21.photobucket.com/albums/b265/Brittany-O/4ab1a3eb.jpg)
![](http://i21.photobucket.com/albums/b265/Brittany-O/a98b3532.jpg)
![](http://i21.photobucket.com/albums/b265/Brittany-O/21f8cfc1.jpg)
That was the first thing that came to mind. But it was the exact length as the lingenfelter. Plus you can tell by where the splines are twisted on the yoke, it was only about half way up the yoke. Just curious to how it busted the tailshaft when nothing is attached to it.
