shifting into 4th feels like second need help
alright guys here is my prob... while normal everyday driving the gears shift like butter... now when i get on it from 1st to 3rd its awesome once i go into 4th the car feels like it goes into 2nd but its in 4th and makes the car just start backfiring until i put the clutch back in.. the car only has 42,000 on it and about 3,000 on the new clutch, slave and master... iv also noticed that the fluid has a tint of black in it and its never been like that before??
any advice would be grateful
well i have a pressure gauge on the fuel rail and it stays at 60 all the time but once i park it and turn it off the pressure drops down to zero after about 3 hours and it use to stay at 60 all the time... i installed iridium ngks about 2000 miles ago along with wires ill pull the plugs tho to see if there fouled out... can you guys explain whats happening when you say its under load??
if fuel isn't meeting eng. load, you may backfire.
fuel required in 4th > fuel req. in 3rd > 2nd > 1st
incorrect timing could cause backfire too, but that's a lot less common an issue.
