What manual trans&clutch setup will handle 1000whp?
I believe the GF4A is rated to 800ft/lbs 1000hp, they where used in stock car racing so used boxes and good builders are abundant. I think gforce has a number of transmissions that fit your bill, but be prepared to pay.
Your going to need huge steam roller slicks, a built 9", and a hell of a drive shaft to match.
Thats what he was telling you...remove the drain plug, and put a fitting in it's place, hook it up to a pump, hook the other side of the pump up to the spray nozzle that you need to add to the case where he showed in that picture...this way it circulates whats in the transmission constantly, and makes sure the most important parts in front are oiled/cooled.
Fill normally with the fill plug, but add enough fluid to fill the pump and lines, and when you want to change it...just remove the fitting from what used to be the drain plug to drain old fluid out.
If you're REALLY adventurous, and have a pump that can handle it, you could even add a fluid cooler and filter inline between the pump and sprayer.
