New LS9X clutch for F-body/GTO
We are now taking pre-orders for the LS9X clutch kit for F-body/GTO. The F-body required more custom parts to make it work so that is the reason it is priced higher than the Corvette kit. $1849.99
http://store.katechengines.com/ls9x-...ygto-p254.aspx
I'll announce a firmer delivery date the week of 1/24/11, but right now estimating about late February or early March. You can get your pre-orders in now to reserve your parts. Your credit card will be authorized but we will not charge until it ships.
-For 1998-2002 Camaro/Firebird V8 & 2004-2006 GTO
-Twin disk clutch
-Clutch disks and pressure plate from the ZR1
-Aluminum flywheel with 6 bolt pattern for standard LS engines
-Includes Katech custom slave cylinder
-Includes pressure plate bolts
-Includes bellhousing spacer (less than .5", requires no modifications)
-8lbs lighter than the stock Z06 clutch/flywheel assembly
-Flywheel weighs 12.0lbs.
-Drives like a stock ZR1 - stock pedal feel
-Proven to 700rwhp (drag racing) 800rwhp (street)
-800+ ft-lbs torque capacity
-No neutral noise or chattering
-All of the benefits of a twin disk clutch and none of the trade-offs
-Twin disk clutch
![](http://www.nexternal.com/katech/images/KAT-A5198_lowres.jpg)
It's a Katech flywheel. We've had great feedback on it in our existing applications (Corvette C6, V1 CTS-V, G8 GXP, 2010+ Camaro) and have now expanded to two more models. The GM parts in this kit are the pressure plate, bolts and disks. The rest of the parts we make. If I remember correctly the disks are around 11".
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Is the higher capacity LS9R available ?
And what is the 1/2" bellhousing spacer for ? What does it affect installation wise ?
And why is the F-body version so much more expensive than the Vette or CTS-V ?
What's the difference ?
Mine wouldnt be going in any of the above cars, hence the question. Although I'm on an LS2 motor with a Camaro based T56 with Quicktime bellhousing.
So no idea which version I'd need ?
The F-body did not have enough space to fit the LS9 clutch and slave cylinder, so we had to design a special slave cylinder and move the trans back roughly a half inch. Those extra parts are the reason for the increased cost.
Go by the trans you're using. So if your T56 and bellhousing is for F-body then that would be the kit you need.
Yes, the LS9R is available.
Would there be enough room in the Quicktime steel hellhousing, or is it a simple fact that the BH height just isnt tall enough ?
That amount of movement would necessitate a new propshaft ( driveshaft ) on mine, as I cannot move the trans back that amount, nor could I move the engine forward.
yes the QT I am using is F-Body fitment.
Does the outer diameter of the cover foul the bellhousing, or is it simply the stack height ?
What is the stack height from crank flange to clutch fingers, as installed for an LS9 package ?
Baring in mind I'm currently using a triple disc which already has a shortened slave to accomodate it's extra height. Although It's outer diameter would definitely be smaller than the OEM LS9 clutch.
