Just got an L96 and want t56; easiest way to get T56 behind it?
I also like the idea of getting one w/.62 final drive. Going into GM A-body that already had an Lt1 t56 (so shifter location already back). What are your thoughts since I'll need a complete change over?
I'd like to get either a used one super cheap w/everything that I can just have rebuilt now before it goes in, or one that has been already redone. My engine has 3k on it, and I want to not worry about the tranny. At most I'll have exhaust/cam mods so I'm looking at ~ 500FWHP.
Thoughts?
Thoughts?
I sell reman'ed T56 transmissions, but am running very low on stock. Price is $1900 outright for a "better than new" unit. Freshly built with billet 3-4 keys, steel 3-4 shift fork, true press-fit 5-6 gear cluster (modded mainshaft). One year warranty, unlimited mileage. Or if you want the 31-spline HD mainshaft upgrade, price is $2500.
Will probably be going w/TDP for a tranny; but I'm reading that the LS7 clutch package may be a better fit.
Re .62; read another post saying that was GTO final ratio--guess that was wrong. I just didn't like the 6th in my LT1. Really needed to be going over 60 w/flat road for it to like it. Maybe w/LS power it won't lug as much. I have 3.73s running 235/60/15s. Thinking the .57 may be better way to go and TDP says can swap those in.
If you buy a transmission from me, I'll make you a really good package deal on a clutch too. I can give you the special, along with another $50-100 off the entire package. Everything is warrantied for one year regardless of mileage.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
The "LS2" flywheel goes with the "LS7" clutch, and makes it a complete kit. You have to switch to that flywheel to make it work. However, I recommend staying away from the LS7 setup. It's nothing more than a glorified stock clutch. Sure it's a little stronger than the LS1/LS6 setup, but still a stock clutch. I'd be telling you the same thing even if I wasn't in the business of selling clutches. I recommend going with a Diamond Clutch kit. It's a little more expensive than the LS7, but much lighter and stronger. The Diamond Stage 1 is similar to the LS7, but has a stronger pressure plate. Most people go with the Stage 2 dual friction setup. It's really a perfect street/strip clutch. It drives really close to stock and can take a beating with a 600hp/tq capacity.
If you buy a transmission from me, I'll make you a really good package deal on a clutch too. I can give you the special, along with another $50-100 off the entire package. Everything is warrantied for one year regardless of mileage.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
