Flywheel bolts, New one or old ones???
hey everybody. So i just bought a LS7 clutch kit. came with LS7 clutch,PP,LS2 flywheel. and a brand new master n slave cylinder. both GM ones. My question is i did not buy a bolt kit tho. you kno the bolts for the fly wheel or the PP bolts. is this something i should do or just use the old ones. and em i forgetting to do anything special since its going on a 99 z28? im not sure if i can cuz by now money is extreamly tight but i assume so. Also since its a kit do you thing the flywheel is balanced or should i have it done. This whole project is for my 99 Z28. Thanks for the advice fellas.
The only thing I can think of that you are forgetting is a new pilot bearing, cheap insurance around $12.00 and now is the time to change it while you are in there. Make sure you use some sealant on the flywheel bolts as they go into a oil galley.
Does the flywheel bolts go into an oli galley on the LS3 engines?
