What clutch?
Anybody know anything about the monster clutches?
There are multiple "good" clutch companies to chose from.
My $02 is with the power you will be making and the weight of the truck you should consider a "dual disc" clutch vs single disc. If you go with a single disc than one with a more aggressive disc like many make (3 and up) but some street maners will be left behind. A dual disc will keep those but hold very well with the HP you make.
The dual set up will cost $400+ more but will last under "spitited" use with very good street maners (no chatter)
There are always trade off's. A aggressive single disc can hold the power but give up some street maners (street maners is subjective, some feel a aggressive single disc is fine while others don't like the chatter). A dual will hit the wallet harder but IMHO live way longer and drive like stock but have a firmer clutch pedal.
I would also get a drive shaft with 1350 yokes...sounds like you will be making some power and of course wanting to use it :-)
McLeod, SPEC and I assume Monster should make a twin or single disc clutch for your application
