Anyone use 5th gear in the 1/4?
I was contemplating gearing the rear in my Z28 to utilize 5th in the 1/4, anyone try this and can the trans(t56) handle say 435rwhp this way?
The two-piece countershaft can be a liability if the counter parts aren't shimmed properly and depending on power level. Should be fine at 435 na hp but the fork pads will be the first thing to go with ham-fisted shifting.
You're also going to have a case of diminishing returns with regard to time spent shifting; to finish at redline in 5th and have a well matched 1st/rear gear ratio is going to take more than a bolt-on type setup.
I had been year before last while using 26" slicks trapping at 142.. Car went faster using 5th as opposed to riding limiter by about .05 for me.. It held just fine for the season.. Now trapping 146 with 28"s in 4th..
New 5.0s with 373s are geared to shift into 5th but I don't see to how its beneficial. When I hit 5th in my car it feels like you dropped a elephant through the back glass.
T56 5th gear is an overdrive, or below 1:00:1 and that's why your car fees like **** in 5th gear.
I see no benefits to this, and you will probably go slower...adding yet another shift...
