Spec stage 3 is in.
Old 03-13-2004 | 02:03 AM
JimmyY2KWS6's Avatar
Thumbs up Spec stage 3 is in.
I installed my my spec Stage 3 (Xpad) clutch today and everything went smooth. It took me and my brother about 6 hours to finisih the job. I also did the Master/Slave as well. The clutch pedal has a good feel to it and there is little chatter but I think it will go away. I only have 2 miles on the clutch right now. Overall I am very pleased with the setup. I just can't wait for the first 500 miles. I want to see how good it holds
Jimmy
Old 03-13-2004 | 04:28 PM
deviate42's Avatar
sweet
once that clutch breaks in, im sure youll like it even more
Old 03-13-2004 | 04:49 PM
99CamaroSS's Avatar
Nice, I'm considering which clutch i should do myself. Did the Spec come w/ everything? Flywheel, Throwout bearing etc.? Keep us posted especially after those 500 miles. Thanks
Old 03-13-2004 | 05:25 PM
NHRATA01's Avatar
I've got about 1.5k miles on it and it feels great now. The first 500 miles were a bit tough, and the first 100 a bear. It chattered a bit at break in and engagement was just off the floor. Now the chatter is just about gone (expect that when I go to 4.10s it should get even better) and the engagement is just about in the middle of pedal travel.
Old 03-13-2004 | 05:43 PM
I just came back from a long drive (100 miles) and I agree with NHRATA01. The first 100 is a bear. 400 miles to go then it is track time!
99camaroSS,
I ordered the spec clutch flywheel package and I got everything except master/Slave. It even came with an alignment tool as well. Good luck
Jimmy
Old 03-13-2004 | 09:14 PM
99CamaroSS's Avatar
99camaroSS,
Jimmy
Cool thanks, never done it before, so how hard is it to align whatever needs it?
Old 03-13-2004 | 10:34 PM
thechef's Avatar
Moderator
the SPEC is a great clutch and they grab like a **** i got 30k miles on mine and we sell alot of them
Old 03-13-2004 | 11:40 PM
It is not hard when using the tool. you just insert the tool into the clutch and flywheel, torque the Pressure plate to specs and install the bellhousing back on. Remove tool and insert transmission. It is really not that hard. Just take your time. If your clutch is not aligned the tranny will never go in. The tool almost eliminates that possibily.
Jimmy
Old 03-13-2004 | 11:52 PM
99CamaroSS's Avatar
Jimmy
Cool, sounds easy. Can you keep the stock bell housing? I heard some guys for some reason replaced the housing when doing the clutch, ever hear of that?
Old 03-14-2004 | 12:15 AM
I never heard of that. The stock housing worked just fine. You do not need to replace it.
Jimmy
Old 03-14-2004 | 01:23 PM
14u2nv's Avatar
Whatever you do, break it in properly! Don't be in a rush to beat on it or you will regret it.
Old 03-15-2004 | 12:38 PM
Jabroni's Avatar
800+ miles on mine. Most of the chatter is gone than from when it was new. It will still chatter a bit if I don't drive it right but that's about it. So far, a good clutch.
Old 03-15-2004 | 11:30 PM
I just finished 500 miles on it today. I did not do any clutch dumps yet but I got on it and I was impressed. I spun 3rd hard and I was surprised to bark 4th gear. That clutch holds like a **** It still chatters a bit but is getting better.
Jimmy
Old 03-16-2004 | 01:42 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
500 miles! Jimmy, I don't know if I can wait that long when mine goes in this week...
See ya at the local meet.
Old 03-16-2004 | 04:58 PM
Cool
yup 500 miles! I drove it off in 3 days so I get to test it out You will love yours. That clutch has an awesome holding power, it breaks the tires loose in 3rd and 4th See ya at the meet.
Jimmy
