Newbie M6? Trick to getting into reverse?
Old 03-13-2004 | 08:26 AM
11 Bravo's Avatar
Default Newbie M6? Trick to getting into reverse?
Finally got my car converted. I am having a problem getting into reverse most of the time. It keeps wanting to go into 5th instead of R. I have to mess with it for a few seconds before I can get it into that gear. Is there a trick to it? FWIW I have a Pro 5.0 shifter (kicks *** btw).
Old 03-13-2004 | 09:03 AM
bspz28's Avatar
I put mine in first then go over to reverse works everytime
Old 03-13-2004 | 09:52 AM
trackbird's Avatar
If you converted it, did you hook up the reverse lock out solenoid on the side of the transmission? Most guys either install a switch to put 12 volts on that solenoid or they hook a high current relay to a set of contacts on the brake switch (so if you are on the brakes, it will go in). The only "problem" with the brake switch idea is if you are slowing down and make an upshift (you "shouldn't" do that, but many of us do) from 4th to 5th, you could find reverse. The reverse gear has a "crash through" gate which is why if you hit it pretty hard it will still go in.
Hope that helps!
Old 03-14-2004 | 04:18 PM
distortion_69's Avatar
Which stick are you using? Believe it or not, I had to switch back to the stock pro 5.0 stick from my short stick. It wouldn't go into reverse with the shorter stubbier stick worth a crap, and I'd have to take both hands and push it over past fifth into reverse. Swapped back to pro 5.0 stick in parking lot and voila, back to normal.
Josh
Old 03-14-2004 | 06:06 PM
11 Bravo's Avatar
I think I have the hang of it now. I have the 5.0 stick.
Old 03-14-2004 | 11:50 PM
Transamula's Avatar
I have the same problem and I'm totally stock. Not sure what is causing it since it's been doing this since it was BONE stock (not anymore, Finally ditched the cags! ) I think it's just a little tempermental. EVERY manual transmission has some quirk, at least any that i've ever seen or heard about from friends.
Old 03-15-2004 | 12:15 AM
ta12sec's Avatar
Hard to get reverse can aslo be qa sign of a clutch not disengaging fully.
Old 03-15-2004 | 02:34 AM
deznuttzz28's Avatar
thats how i do mine... or sometimes push the stick all the way to the right
then up..
Old 03-15-2004 | 06:37 PM
slow's Avatar
i put mine in 2nd, then reverse. Slides right in.
Im fairly sure that is what the manual states to do as well, if it is hard to get into reverse.
Ryan.
Old 03-15-2004 | 08:49 PM
Keenov's Avatar
I come to a complete stop before taking it out of gear and sliding it over to reverse. It works fine.
Old 03-15-2004 | 09:04 PM
Xerxes's Avatar
Put it in any gear first, then into reverse. Reason you have to do this is because reverse is a non-synchronized gear
Old 03-16-2004 | 01:32 PM
1CAMWNDR's Avatar
Thumbs up
Also, make sure when you put it in 1st that you let the clutch out enough to feel it engage, this will help line everything up inside . Works every time for me.
Old 03-17-2004 | 07:44 AM
calhoon's Avatar
Reverse in the 6 speed IS fully synchronozed. The only thing entering another gear first will do is re-index the trans and allow better synchronizing. If you put the CAGS device in the wrong solenoid harness , it would give you the reverse shift problem you describe.
Old 03-22-2004 | 09:45 AM
98 SNAKE EATER's Avatar
I usually put it in 4th, then Reverse...
Works every time
