Any one had a clutch explode with a ls1/t56 combo?
I will be getting an sfi bellhousing over the winter, I have been having a huge fear my clutch will explode Leaving the line at 7k+ na and around 6300-6600 on spray.
My question is have any of you ever had one come apart? what was the situation? and when did it do it? got any pics? Still have your feet/toes?
My uncle was the one to strike fear into my heart. He is an old nhra stocker guy and he had one let go on him, but he had 1/4 inch steel welded to the trans tunnel so no injuries. (this was way back in the day of course)
It's only going to take it happening once for you to reconsider going with something like a Quicktime Bellhousing. I know they are pricey but how much is your leg worth to you? I really try to push them when selling a transmission or clutch package to a customer making over 500 fwhp.
Left at 7700 off the line, had a slight vibration, thought it was the tires, on the big end at 7000 it got really bad, as I backed out of it, it went boom, pieces of the block everywhere, the clutch it self was mostly intact, counterweights were gone as was some friction material...could have been alot worse though.
I had one grenade a couple of months back, pressure plate let go....
No bell housing left
chunks out of block
chunks out of gearbox
tunnel hammered but nothing came through thankfully
4" cut in fire wall
took out brake lines
took out air con hard lines
broke the back off the inlet manifold
trashed the wiring loom
crushed the exhaust
chunks out of block
4" cut in fire wall
crushed the exhaust
