Clutch Disengage Issue..Please Help
Ok, I want to start off and say I have a 00 Ta with a freshly rebuilt t56....I put a brand new textralia clutch in it, with a Tickshift master cylinder and a new slave cylinder with the speed bleed setup.
I was driving the car one night really hard on the street...donuts and such things and high speeds.
When I pulled up to a light...I pulled the car in neutral...When the light turned green I tried to put the car in gear.....PEDAL WAS SOFT...wouldnt go back into gear.
I therefore had to start the car in second gear and cruise to my place which was only down the road.
I bled the fluid hoping it would stiffen the pedal back up....but I am still moving fluid through the speed bleeder line...My question is could the slave cylinder still be my problem possibly? It was brand new with maybe 3,000 miles but probably hard miles....Have you guys ever heard of one failing so new? Or could this be a clutch problem? Thank you for looking...
I dont have a tick MC so i cant speak from experience, but ive heard of others over-extending the slave because it was not shimmed properly or the tick MC was not adjusted correctly. Might wanna look into that.
Is there a way to replace the seal on the slave or do you just keep buying up new ones every time you replace the clutch. seems like a waste of money.
I have a question though, If my slave cylinder is over extended wouldnt I see clutch fluid underneath the transmission? I do have a blow proof bellhousing, but there isnt a gasket between the transmission and the bellhousing so dont you think the fluid would seep through?
Thanks for all the help!
