T-56 help
Also, sometimes while stopped 1st gear seems to not be aligned up in gear but DOES NOT give me trouble getting into 1st. Like clutch in, attemp to go into 1st, won't go, clutch released, clutch in, goes into 1st no problem...???
An help much appreciated!!
I'm not joking when I say they fucked you. I guarantee they charged you for parts they did not use.
I purchased my trans am for cheap because the owner was told there was nothing wrong with his transmission when they failed to put in a new slave, new pressure plate, new throw out bearing. The car rattled like hell and had a massive vibration above 2500 and they refused to work on it and said the motor was toasted. Please look up their reviews on google.
The slave and throw out bearing need to be replaced. Take it anywhere but aamco to fix it, not joking when I say they intentionally re use old parts and charge you for new ones. Check their reviews
My throw out bearing rattled any time you depressed the clutch
My car vibrated because they did not correctly tighten the flywheel
The previous owner gave me the invoice and they charged him for all new parts and a disposal fee for the old ones
It's probably sticking because the slave is contacting the throw out bearing
almost forgot, they also completely screwed up the connection from the master to the slave and jb welded it back together and it was causing the pedal to slip as well
I feel a HUGE diefference between my 2002 Z M6 shifter to my 98 t/a M6. The t/a has lots of play while shifter in gear. The Z I feel and hear the firmness of moving the shifter at all times. Makes the crisp clanking noise where my t/a is weak and makes dull clanking noise. Is it the shifter cup bushing? or something internally weak in the t/a t56?
Thanks
If you dont do any of the work yourself you might need to call a transmission rebuild vendor and ask him for his opinion on your situation. Tick, TDP or any other shop im sure could answer your questions relatively quickly
but bottom line i would have your slave and throwout bearing replaced and always ask for the old parts from any shop that works on your car. Never take their word that they replaced a belt or put new brake pads on without seeing your old parts. but thats me im paranoid about shops
