Mgw shifter issues still not resolved new transmission
Ok I bought a t56 from tick and didn't want to use stock shifter so I bought a new mgw shifter and I worked great until about two weeks ago it doesn't return what so ever to left from 5th to 4th and from 4th to 3rd it has to be moved on a angle to go into gear I have read every thread and there was no resolution does anybody have a ******* clue on what else can cause this issue I also have the viper springs in the shifter now Plz help if you have any inf
Here are your other two threads.
https://ls1tech.com/forums/manual-tr...il-tranny.html
https://ls1tech.com/forums/manual-tr...w-shifter.html
If you read and follow instructions, you can read a comprehensive thread about this issue where someone RESOLVED their issue.
Tip: It has about 20+ replies and is in the manual transmission forum.
At jmd no one has resolved this issue if you read the posts trust me someone has already put the viper springs in it and they said mgw said it was their tranny mine is brand new and does has similar issues so if you could find a resolution in any of the posts feel free to share them
The transmission does not center the shifter left to right. The shift mechanism from inside to out has nothing to do this in non Y-body T56s.
The shifter centering is done by the springs in the shifter. Your MGW is probably just as easily disassembled as a factory Hurst which has simple shimmed springs.
In the thread you may or may not have read yet where the problem was resolved, it sounds to me like someone had some smoke blown up his bum in blaming the transmission.
Every bit of the above has been in prior threads. Multiple people with the same issue and the same shifter are usually not a coincidence.
Only the springs in the shifter is responsible for centering the shifter when in neutral. There are no centering springs in the transmission itself. If its not centering then there is probably binding in the trans preventing the shift rails from rotating smoothly.
