Does my shifter have stops?
Old Mar 30, 2004 | 04:49 PM
BadAndy's Avatar
Default Does my shifter have stops?
Does my shifter have its own stops? Hurst competition plus.
Old Mar 31, 2004 | 08:58 PM
ihada69l78's Avatar
The factory Hurst doesn't have the stop bolts.
Old Apr 1, 2004 | 11:19 AM
BadAndy's Avatar
I don't have a factory Hurst, I have a competition plus.
Old Apr 1, 2004 | 12:11 PM
shiznit's Avatar
all t-56's have built in stops in them
Old Apr 1, 2004 | 12:20 PM
BadAndy's Avatar
Christ, thats not what I asked.
Old Apr 1, 2004 | 07:47 PM
SSTYCOON's Avatar
My Aftermarket hurst has the bump stops
Old Apr 1, 2004 | 08:08 PM
jaberwaki's Avatar
how bout pulling off center consol (8 screws come on ) and looking
Old Apr 1, 2004 | 08:49 PM
BadAndy's Avatar
What's a stop look like?
Old Apr 2, 2004 | 09:19 PM
jaberwaki's Avatar
like a small bolt on every end point for each gear....
looking down on your shifter you should see then sticking into it from the sides...
i'll see if i can find a pic somewhere....
Old Apr 3, 2004 | 12:20 PM
ihada69l78's Avatar
The after-market Hurst Billet plus has the stop bolts. There is one on the front side and one on the rear. It's a bolt with a jam nut.
What are you calling a competition plus?
If it came from Chevrolet it doesn't have stop bolts.
Old Apr 3, 2004 | 01:18 PM
tuffluck's Avatar
dumbass time - what's the purpose/benefit of having stops?
Old Apr 3, 2004 | 04:28 PM
BadAndy's Avatar
There are three hurst shifters for the Fbody T56. Factory hurst, Competition plus, and Billet plus. I know the Billet Plus has adjustable stops. I want to know if the Comp Plus has stops.
Old Apr 3, 2004 | 08:34 PM
ihada69l78's Avatar
Shifter stop bolts: After the gears are engaged, continued pressure on the shifter can cause excessive wear or parts breakage. IMO they are only needed in cars raced often unless you try to rip the shifter out of the car every time you shift on the way to the grocery store. Use em if you gotem.
1998 Z-28 M-6, Proud owner since 12-30-03. 117,000K. Still almost stock
1987 Buick GN 75,000K
1969 Nova B/S
2003 Silverado
