Shifter/Trans Rise when on gas
Hey guys,
Just bought my '01 T/A WS6 (T56) and couldn't be happier. Few things to touch up on but that's expected for an 11 year old car. Something I noticed after I bought it is that the shifter will rise a few inches when I get on the gas aggressively. There is no shifter play so I'm guessing it is the whole transmission that is moving. I searched around and have come to the conclusion that either my transmission mount is loose, missing bolts or needs replacing. Seems like a Prothane Transmission Mount is the way to go if it needs replacing.
Just wondering where you guys shop or if anyone has a better suggestion. This car is going to be a DD for now. It will definitely see Willow Springs Raceway later in life but not yet.
Thanks for your guys' help in advance,
Cesar
Cesar
it makes sense that the tq arm would cause it, being that under load the front end of it lifts and in stock form its bolted to the *** end of the tranny, FWIW i never noticed it with my car before but it doesnt do it now and i have the tq relocated
No doubt a poly trans mount will help. Just not sure it's the cure.
Hey guys,
Cesar
Cesar
Your best bet is what kyoytey did.
Thanks for all of the replies. Im going to get under it this weekend to make sure the trans mount is bolted down properly. If everything seems fine i will go kyoytey's route. Again, thanks for all of the responses.
Correct me if i'm wrong but I believe you need at least Poly motor mounts or solids to do the poly transmission mount.
You can always just get a new stock style from any auto parts store.
We've got a winner here, I have a Poly mount in mine as well. My shifter used to shift upwards when jumping to full throttle with no tip in, it would jump up and forward. Now it doesn't move at all.
I am curious about this too because I definitely need a new mount.
Ways to fix this:
The only way to truly fix this issue is to relocate the torque arm mount to the body.
Why? Because it is no longer attached to the transmission it will not shove up on it. Duh.
Why shouldn't I put a stiffer mount in? Because when you have a stiffer mount or even a solid mount, you have a much greater risk of breaking the tailshaft. The force from the torque arm is still there, so it has to be absorbed by the trans case.
Putting in all solid mounts is great. Do it. Just use a body mount torque arm as well. If no one else has shown or explained to you yet, you will pick up a lot of vibration from solid or aftermarket mounts. Yes, it was there before, but the old mounts absorbed it.
The Scammer Hammer
I agree with that statement.... in the long run. If you're just looking to get the Viagra out of the shifter when you hammer it, a poly trans mount WILL clear that up.
If you're willing to even go that far though, as Black96 already stated, you should DEFINITELY be in the market for a torque arm relocation kit.
trans mount.. end of story... go buy 23 dollar energy suspension mount and be done with it.. you'll hook up better too, instead of completely obliterating the tires into 2nd... if the trans mount is GOOD, then the torque arm can cause the trans to rise because its firmly bolted to the crossmember... now if mount is broken, then torque arm causes trans to rise.. real simple here
