Monster clutch stage 2
Not to knock the monster stage 2 but, Ive had it for almost 900 miles now and it chatters, reverse is bad chatter. I have to rev it up to around 1500-2000 rpm to get a smooth engagement on both ends. I called monster and they said to beat on it slaming through the gears a couple times to get some of the glazing off, which I did, but didnt really help much. i did this a couple of times. Once driving it feels good, like stock. This clutch has kinda let me down and left me with out $800. I did research about it and thought it was a good choice but now im not very happy. I think Im going to change it soon and go with a 02-04 LS6/ZO6 clutch set up. I have many friends w this clutch and have great success.
Have you checked for leaks?
Give me a call or shoot me an email at steve@monsterclutches.com and we'll go from there. This unit has been proven time and again to be a great daily clutch that will hold power and provide excellent drivability. If your setup is chattering that bad something is amiss.
This isn't the norm.
I cleaned the flywheel and presure plate very good with brake cleaner and followed the 500 mile break in procedure of a lot of stop and go. Ill try to contact you soon Steve.
