Stronger t56
Old Sep 23, 2012 | 01:47 PM
95Banshee's Avatar
Default Stronger t56
I'm rebuilding my T56 and need to know what the weak point of the trans will be when launching. I'm gonna be running 315 drag radials. I plan on doing brass **** fork pads, and Billet keys. What else do you guys recommend.
Old Sep 24, 2012 | 02:34 PM
gnx7's Avatar
Complete rebuild kit with new seals, bearings, carbon blocker rings, new synchros, billet keys, bronze fork pads, and a steel 3/4 shift fork. You probably want to install a 30/31 spline output shaft at that point too!
Unless you are doing the work yourself you won't be far away from the price of a new T56 Magnum transmission.
Old Sep 24, 2012 | 02:43 PM
thesource's Avatar
You're going to need an upgraded 2nd gear as well if its for that Lt1 car.
Old Sep 24, 2012 | 04:57 PM
jmd's Avatar
jmd
The grooves for the reluctor ring clips are where the mainshaft will tend to break. A 30 or 31 spline mainshaft upgrade might make sense.
Old Sep 24, 2012 | 07:16 PM
95Banshee's Avatar
heres 2nd gear most all of them look like this would i need to replace the gears too because if so thats gonna add alot more money and may just buy an already built one. i am doing the work my self and this is for a ls1 camaro
Old Sep 24, 2012 | 08:13 PM
thesource's Avatar
That looks like the later 2nd gear. Hard to tell from that angle but the teeth look like the longer ones.
Old Sep 24, 2012 | 08:19 PM
95Banshee's Avatar
do you think they are too worn to reuse?
Old Sep 24, 2012 | 08:26 PM
thesource's Avatar
No they will be fine. The older gear likes to pop the small teeth off.
Old Sep 24, 2012 | 08:30 PM
95Banshee's Avatar
ok thats the 2nd to worst looking one 5th is a little worse but its going in a drag car that may get driven on the street rarely but i probably wont use 5th much it had grinding problems in 3 and 4th and 5th wouldnt go into gear but all the shift fork pads were missing and the syncro detents were almost all broken i think that was the problem. also 3 pieces were chipped off the 5-6 gear cluster im thinking about running it i dont plan on doing pulls past 4th the only time ill use 5th is if im out cruising and ill just take it easy or use 6th
