lt1 to ls1 t56 conversion question.
Old Sep 24, 2012 | 03:48 PM
stevecritt's Avatar
Default lt1 to ls1 t56 conversion question.
Ok I'm starting my conversion. just a few questions, In the pictures I posted below, there is a ring that is pressed on to the old input shaft. What is the best way about going about geting it off and putting it on the ls1 input shaft? and any tips you can give me while I got it apart.
Attached Thumbnails lt1 to ls1 t56 conversion question.-20120924_163543.jpg   lt1 to ls1 t56 conversion question.-20120924_163550.jpg   lt1 to ls1 t56 conversion question.-20120924_163557.jpg
Old Sep 24, 2012 | 03:50 PM
85MikeTPI's Avatar
Someone sold you the Brooklyn Bridge..
That's a late model double-cone synchro input shaft, won't work on your LT1 conversion.
Old Sep 24, 2012 | 03:58 PM
stevecritt's Avatar
ok well nevermind it looks like that is one entire piece. but that ring fit inside that other sprocket looking ring? am I missing somthing that i need?
Old Sep 24, 2012 | 03:59 PM
stevecritt's Avatar
well ****. What does it go to
Old Sep 24, 2012 | 04:00 PM
85MikeTPI's Avatar
You need a F-body LS1 input shaft that has the same cone shaped machined surface on it for a single-cone synchro. That late-model input shaft uses different synchros and a different mainshaft design.
Old Sep 24, 2012 | 04:02 PM
85MikeTPI's Avatar
Most likely it came from a Corvette C5 T56, or a GTO, depending on the number of gear teeth it has..
stevecritt's Avatar
ok. where can I get one?
Old Sep 24, 2012 | 04:06 PM
85MikeTPI's Avatar
Tick has them new:
http://www.tickperformance.com/treme...camaro-firebird/
or used in the standard places you probably looked for what you have now.. Classifieds, Fleabay, craigslist, etc..
stevecritt's Avatar
and is the one I have worth anything?
Old Sep 24, 2012 | 04:12 PM
85MikeTPI's Avatar
I'm sure it's worth something to anyone needing it. Find out exactly what it's from/for and post it on the same lists where you're trying to buy..
My SSR PDF write-up has alot of background and teeth counts to figure out it's origin..
http://www.eecis.udel.edu/~davis/z28..._Fbody_T56.pdf
good luck
Old Sep 24, 2012 | 04:45 PM
thesource's Avatar
Yeah thats a 2.97 ratio input shaft from a Z06 or GTO.
Old Sep 24, 2012 | 08:53 PM
xx_ED_xx's Avatar
the source you got a ls1 input shaft and front plate? I need one as well
edward.coss@gmail.com
Old Sep 24, 2012 | 09:00 PM
thesource's Avatar
Only new stuff right now.
