Low clutch engagement after WOT RUNS!?!?!
Ok so I needed a new slave cylinder due to it leaking so I figured I would go ahead and replace the master while I was at it just to be safe. So after about 1.5 hours of pumping and bleeding I finally got a pedal and along with the "drill mod" I did the tranny shifts "MUCH" smoother and no longer feels notchy. Now for the bad part while driving around under normal conditions the pedal and engagement point is perfect but as soon as I start running it hard the pedal gets soft and engages really close to the floor then after that I go back to normal driving and the clutch goes back to normal. Assuming my parts aren't defective in any way does that I mean still have air in the system?
^^^ it's clear and everything is brand new that's why I don't get why it's perfect when driving normal but one hard pass first through fourth and the clutch starts to release about an inch off the floor then after a few pumps it comes right back...
Even if the clutch fluid is clear, it can have a small amount of water in it. Doesn't really take much water, either. Once the seal has been broken on a new bottle of brake fluid, the shelf life is about two weeks.
Clutch/brake fluid is alcohol based, and alcohol is hydroscopic, meaning it acutualy attracts moisture out the air.
^^^ I didn't realize even with a lid that it would attract water but that could have been it since it was a big bottle of fluid that was new but it had been opened(dont know how long).Could I just suck the fluid from the master then fill it and pump it drain it on and on? If not then I have to drive back to my dads shop (1.5 hours away) in order to bleed it at the slave.
Have you noticed the car creeping when you sit at a stop with your foot on the clutch pedal? If so you may actually be seeing an internal leak within one of the cylinders. Just another possibility to be aware of.
I'm going to assume it's the stock adjustable pressure plate. Go ahead and try what was suggested with new fluid to rule out water in the fluid but I doubt it. My brother and I both put in new masters, did the drill mod, and put in new slaves and we still had the exact same problems you have. When we get on it hard the clutch pedal gets all soft and spongey and it gets hard to get into gear. We would have to pump the pedal to bring it back to life. Since then my brother bought a monster clutch with a heavy duty "non adjustable" pressure plate and hasn't had a problem since.
I try to address potential issues one at a time because there is no need to overwhelm anyone with too many things to check. That being said, if the car doesn't creep after depressing the pedal for a longer period of time then you aren't seeing fluid bypass the seals. It could easily be the stock SAC plate if you are in fact still using this type of setup.
Well I went for a long ride tonight and everytime I stopped I sat with the clutch depressed while in gear and nothing the car just sat there so I guess i can check they off my list.
Not what I wanted to hear but I was wondering if it had something to do with the stock clutch. The worst part is I'm broke and have no room for a new clutch right now so I guess I will just have to be good and enjoy the improved mpg's that will come along with my new "light" foot...
Ok so my next question is why is the clutch/pp giving me problems now that it has new hydraulics? Is it being extended to far and not being able to come back properly? Well I guess the only good news is that I can still drive it and the wife's truck is paid off this month so I'll be able to save for a new clutch quicker.
