Why is there so much dead space in my Tick MC?
I have a tick mc, monster stage 2, and gm slave. I installed them all at the same time. There is about an inch to and inch and a half of dead space in my clutch pedal. Its really soft then you feel the firmness of the pedal. Ive bleed it many many times. Its really bad when its cold after driving it for a little bit the pedal usually firms up but will get soft occasionally. All the components have about 10k miles on them. Installed them last spring.
its roughly the same maybe a half inch lower. The car shifts and drives fine, its more of an annoyance to me. I love the set up just wish i could get rid of the empty travel
Ive bled it many times in effort to get rid of this. Monster clutches do not require shimming. I will try making it level with my brake pedal tomorrow.
When you try to bleed this out, do you do a full pedal pump or just the dead space?
