Mity Vac Clutch bleed
When using the Mityvac in the reservoir method, if the master has crazy bubble action (think trying to drink that last bit of coke out of a huge *** 7 eleven cup), there's a leak in the system correct?
I'm thinking the Master is cracked and allowing air in at full actuation, I'm ordering the brand new setup from GM just to be sure.
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
The hose from the reservoir to master isn't designed to be vac. tight.
The bleeder is up top and should be used.
copy pasta:
copy pasta:
Originally Posted by jmd
The mityvac pulling from the reservoir means it ultimately pulls from the bottom of the slave and never pulls all air. Search for jmd method if you want all air out.
I've never needed a MityVac to bleed an LS1 car. Put the MityVac on the shelf and use the JMD Method
