flywheel bolts!?!?
its bending the flat parts of the bolt out.. is this gunna be a problem?? or should i just torque the suckers down with locktight and call it good ?
The bolt should sit flush.
you could get grade 8 bolts that did not have the flat outer skirt part that is extending onto the angled part of your FW
I would prob notice if the flywheel started to come loose wouldn't I?
do you have the flywheel tight on the crank yet?
I bet you just noticed its the side of those 2 top bolt because you have the FW just started on the crank register and it tipped in at the bottom more still so only thous 2 top bolt look to be hitting. And the bottom bolts are hitting on the top (inside) more too.
If so, and the FW is not drawn on the crank yet. Get it seated all the way and see if the bolts still look tipped
. ya I was guessing the 2 bolts circled were just the 2 top stops of contact. And it was something simple like that, your tired working on the car in the dark and cold and overlooked something like that, it happens. I know what your saying, the FW radius corner going up to the disc raised surface, the bolt shoulders were hitting the start of the radius. Never seen that too, not this has anything to do with that but only seen the aftermarket cranks not fitting flywheels as "good"... The OEM holes are all over, the aftermarket is tighter and run into problems
I surely wouldn't have modified the bolts, but, that's your call.
