550rwhp 110% streetable (stock like) clutch.
#44
for the people that read this thread and want to know if there monster flywheel will work with the the mcleod rst/rxt twin disk clutch. i got word from Scoggin Dickey that it will in fact work. It is recommended that since they are not a matched set that you surface the flywheel and balance the pair together before installation.
#46
I have about 3-4k on it now. The ONLY issue I've had is that the floater plate has gotten a little more noisy when you push the pedal in. Brand new there was no noise. It's not loud at all but it is there. I had a friend in Japan with an OS Giken twin that sounded like a Ducati dry with the alum guard. It's absolutely nothing like that.
Oh, I got a little chatter when the second disk started to grab during break-in but after beating on it ALL of the chatter went away.
The benefit to the McLeod RXT and Monster Twin lvl 2 is that you can very easily replace the disk if it's too aggressive for you.
If you can afford the Monster over the McLeod the warranty really is killer.
#51
I love my textralia twin disc. I drove it with the stock ceramic discs and it was great. and then I replaced those with some sintered iron discs and it is still 100% streetable. The great thing about the iron discs is that the more you beat on it the stickier they get... So basically they match your driving. It does squeal sometimes, haha, but unless you're a girl that shouldnt be an issue.
