Remote Bleeders - any leaks?
Going to be doing a clutch install, and I want to take the opportunity to put in a remote bleeder.
From what I am reading, it seems this installs with a crush washer and doesn't seal by bottoming out the (AN?) fitting like the OE bleeder does.
While I'd like the benefits of a remote bleeder, I also don't want to risk leaks and other headaches.
What have your experiences been? Does anyone know of a bleeder that seals by fully seating like the OE bleeder? Is the tick the best unit, or are they all basically the same? Tick is $57 shipped. There's another shop that's $20 cheaper and looks very comparable.
I was considering picking up some Loctite 545 pneumatic/hydraulic thread sealant to supplement the crush washer.
All in all, I just want to make sure this will be trouble-free. If it matters, I am planning on putting in a Duralast slave cylinder - will make sure it has the "AP" marking on it.
FWIW, the bleeder end doesn't bother me - I have a Motive powerbleeder I'll be using for the most part to bleed. The "speed bleeder" aspect of the setup provides minimal benefit to me. Worse case, I can put in a standard bleed valve. I am more interested in:
1) Knowing I am not running DOT3 into my bellhousing during bleeding.
2) Not having to jack up the car, and get my chubby *** underneath it to bleed.
3) Having a no mess solution to bleeding.
Kleeborp the Moderator™
I've installed bleeders with and without the crush washers, and never had one leak on that end. I have had one leak due to a crappy bleeder screw, but that was easily fixed.
My remote bleeder has been on for 2000 miles, no leaks.
Awesome - I have one waiting on the install. Was very pleased with the product from first glance - seems to be good an solid, and the standard shipping was great too.
Picking up my clutch and the rest of the odds and ends should be arriving via fedex today. Hopefully I'll be able to drive it this weekend!
There was NO WAY I was doing my last clutch swap and NOT doing one of these. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Mine has been on for 5 years and 50K miles, with not ONE drop of RBF 600 lost!!
