finally went faceplated....love it!
Been on the fence about faceplating my t56 for awhile now. I had a spare trans just sitting around the garage and stumbled across a deal on a new faceplated gear set and pulled the trigger. Built the trans and put it in the car this weekend. This thing is awesome! It's nowhere near as violent/clunky on the street as I was expecting based on what I had been told, you just have to know how to drive and pay attention to what you're doing. I've put about 5 miles on it now and I can already upshift it with almost no noise at all by double clutching. Downshifts require a good rev match to be smooth and I've about got those figured out.....get it wrong though and that's where she'll make some noise! Power shifting at WOT is literally laughable. It's like an arcade game! I could shift the synchro'd box almost as fast, but now the shifts are completely effortless and I KNOW it's going into gear every time. Super happy with deciding to go through with it.
Here's a vid of my first street driving experience and a quick WOT rip up an on ramp at the end. The noise from the trans is echoing in the cabin some, it's actually quieter in person than the vid suggests.
You don't HAVE to double clutch to drive it easy. It just makes less noise and keeps it from banging around so much. Like I said, its not for everyone. I have a pretty loose definition of "streetable" compared to most....
just remember it will go back into 1st as easy as it goes into 3rd unless you set up some kind of lock out. I Hope your t56 mainshaft holds up better than mine!
the pass following this one the mainshaft bent so bad it broke my tail shaft housing in half.
thats badass... Im sellin my car this week, But will have another in a year or two, once I get settled in down in Houston... Will definitely be going Faceplated after seeing this... I knew it couldnt be bad... every motorcycle is a faceplated/dog-ring type tranny... And the way i see it, using the clutch IS HARDER on it than just Blipping the throttle and yanking the lever.... there is LESS shock when just blipping the throttle.. You dont have the shock of the clutch drop on every gear change..
Ren's cam only m6 ls1 on 150shot runs low 10's 1/4 - YouTube
first time i went out and tried giving mine a beating i went 1st, 2nd, went to go get third and just like ren said it went right back into first effortlessly and when i let the clutch back up i found out real quick it was in first hahaha. Most of the time i dont double clutch mine. i just let it clunk a little. just push the clutch in and throw it into the next gear quick. It is not nearly as bad as people say. It all depends on what you want, but ill take a little clunk, and be able to shift through the gears as fast as i can.
For those of you who have done this please give me more detail as in '"street manners". It seems to me as long as you accelerate like a man it shifts pretty firm and smooth. As long as your not stuck behind grandma or in traffic you most likely won't have to doubble clutch or deal with the clunk. As for down shifting, I love to downshift, and this looks great for my style of driving. I mainly cruise my backroads which require frequent shifts. I was told this is only for racecar's that shift above 7,500 RPM. It looks like its only for ppl who really like to shift. Correct me if I'm wrong please.
